super
my zorst...
I have a full S/S exhaust system that came with the car. It has started blowing alot recently so had a look to see.
seems its blowing from the cat-blank which is also built like a flex pipe as in its woven rather than a straight pipe. Could i just replace the blank with a pipe or do I have to replace like for like?
Sounds like a tractor!!! :camp:
Normally de-cats are just straight pipe. Should be a flexi joint on the downpipe end as the system does need a little movement.
theres a flew joint on the downpipe yeh....i couldnt work out why they would use this over a metal pipe :cuckoo:
I'd consider taking it to a zaust specialist for them to have a look.
They might think that it is a good idea to replace it with another section that has flexibility in it.
gota cut those clamps off first! tried to get em off today but those nuts werent shifting for shit! haha
