20vtvw 0 Posted April 3, 2009 were there more than 1 type of subframe on corrados ive removed mine (from 1990 16v shell)to clean up and fit poly bushes but also have another 1 from (apparently)a 2.0 16v but the mountings are on an angle and mine are flat also the 2.0 16v?one has a much fatter arb wich i would like to fit to my subframe will it fit?? :confused4: :shrug: Quote Share this post Link to post Share on other sites
ProdigalSon 1 Posted April 4, 2009 Can't answer definitively, but I know that the Corrado and Mk2 Golf subframes are different - are you sure both of yours are from Corrados? Also I believe there are some differences between 8V, 16V and VR6 subframes (as you might expect with different engines/mounting points), but can't find any specific proof, so am happy to be proved wrong... Quote Share this post Link to post Share on other sites
boost monkey 0 Posted April 4, 2009 don't put a fatter front ARB on, it'll handle like a drunk pig on a skateboard. Unless you super beefy up the rear one. The KR and 9A (1.8 and 2.0 16v) subframes should be almost identical. Can you get some photos up? Quote Share this post Link to post Share on other sites
