andreiz2132
Testing Lambda Sensor with a multimeter
Does anyone knows how to test a lambda sensor (4 wires) on a vw corrado 2.0 16v with a multimeter? what are the correct voltages, rezistence, between what wires, testing when idle or when running?
put the voltemeter on the signal wire...once warmed up it should cycle between 0.1 - 0.9 volts every couple of seconds
