vwdeviant 0 Posted April 13, 2009 Ok so thanks to a semi-stuck N/Side rear caliper I now have to do rear discs and pads... Was thinking just gothe stock VAG route, but wanted some recommendations... on upgrades. was thinking maybe going Pagid fast road Pads and stock discs? Or should I go grooved? Also Rebuild stock rear calipers or go mk4? Your recommendations on what to look for and also what to avoid! Quote Share this post Link to post Share on other sites
Toad 0 Posted April 13, 2009 Standard vag disks and pads, or perhaps mintex 1144 pads. Might go vag disks and 1144s all round on my VR if I can find someone selling the pads... Quote Share this post Link to post Share on other sites
dragon green 4 Posted April 13, 2009 Go mk4 calipers,very easy to do, look better aswell Quote Share this post Link to post Share on other sites
dragon green 4 Posted April 14, 2009 theres been lots of threads on here about this topic, i think the ferrodo "2500" came out tops, discs are all down to personal choice, grooved,dimpled,drilled are ok on the track ,dearer then standard,maybe over the top for "normal" driving ! But look cool behind a decent alloy you pay your money, you take your choice :wink: Quote Share this post Link to post Share on other sites
dragon green 4 Posted April 14, 2009 i used to have tarox for 80 000 miles, then went to o-6o-0 discs ! couldnt feel any difference look cool though Quote Share this post Link to post Share on other sites
dukest 0 Posted April 14, 2009 standard rear discs are never going to look cool as they're too small :grin: the rears will never do enough work to need drills or grooves but i would try to match the style with what ever you have on the front for looks. standard vag discs would be fine i think though. what pads do you have at the front? oh, and do you want this bumper? ;) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 14, 2009 Deffo stick to standard VW for the discs - the grey coating stops them corroding like others and they are only a couple of quid more than pattern ones. Pads don't really matter at the back imo but if your getting the MK4's then get genuine ones again with the adhesive backings - late MK3 GTI though, not MK4 Quote Share this post Link to post Share on other sites
Lufbramatt 0 Posted April 16, 2009 Deffo stick to standard VW for the discs - the grey coating stops them corroding like others and they are only a couple of quid more than pattern ones. Pads don't really matter at the back imo but if your getting the MK4's then get genuine ones again with the adhesive backings - late MK3 GTI though, not MK4 or the ATE ones from ECP, which are the same as the VW AFAIK. defo have the same grey coating on. Quote Share this post Link to post Share on other sites
