corrado9a 0 Posted April 23, 2009 Hi guys I have the following problem The gas cable pops out of the pedal when acting quicky and hard on the pedal. The rubber insert from the pedal and the hook from the cable looks ok and seems to fit tight and firm. As a license saver is not such a bad problem but is a real pain in the .. to stop in the middle of nowhere with absolutly no power, remove the lower consoles and re-attach the cable in place. It started to happen a few months ago and it has happen like 5 times since. Any ideas on why is this happening, fixes? thanks in advance Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 23, 2009 your cable is too tight for full throttle, slacken the adjustment of the cable (just before the trottle body) and move the throttle to the fully open position, reset the cable adjustment at that position. It shouldn't pull on the throttle at idle and equally make full throttle before your foot is to the floor, can't remember, isn't there an adjustable stop on the floor under the trottle pedal too? Quote Share this post Link to post Share on other sites
