blue95
QPE 20vt Standalone Idle query
Just wondered what idle peeps get on startup and when the car is warm?
Does the idle change once engine is up to temp?
Mines seems to be idling around 1250-1300 rpm
mine idles at around 1000rpm. doesn't really change after warming up
Does the QPE use the DBW throttle? Or are you guys having to run cable throttles and no idle control?
No DWB, runs using cable throttle. There is an idle adjustment screw but there is no adjustment, may need to mod it. However the throttle was used before on another 20vt setup and was runnning fine. :scratch:
I have emailed Ben (QPE) and it seems I may have an air leak around the inlet, so need to check gaskets etc :(
