corrado1991 0 Posted May 1, 2009 hi i have a 1.8 16V corrado and i am having trouble locating the thermostat! sounds stupid i know and i cant find this question anywhere ! have looked behind the water pump and from the top rad hose in the engine block ! does it have sensors on it ? sorry to ask such a simple question but it is really bugging me :bad-words: ! thanks ! Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 1, 2009 follow the bottom radiator hose to the block, it's in plastic elbow that connects the hose to the bottom of the water pump PITA to get at, need to remove PS pump and associated brackets Quote Share this post Link to post Share on other sites
corrado1991 0 Posted May 1, 2009 Thanks ! i will tackle it today ! Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 1, 2009 you need a new o-ring and don't over-tighten the little 10mm bolts, better to just nip them up with a bit of threadlock on them. Quote Share this post Link to post Share on other sites
corrado1991 0 Posted May 1, 2009 you need a new o-ring and don't over-tighten the little 10mm bolts, better to just nip them up with a bit of threadlock on them. yer have it all done now ! thanks, thankfully none of the bolts for the bracket that holds the PAS pump were rusted ! so im gunna fill her up again and see if the fan kicks in ! thanks again Quote Share this post Link to post Share on other sites
