MARLBORO_LITE 0 Posted May 2, 2009 Apologies beforehand if I am not referring to this part correctly.......... The panel I need to remove appears to support the radiator, so is the correct phrase lower radiator subframe? Anyhow, I need to remove mine and replace it with one that is not made of tin foil! Can ayone walk me through the procedure to remove/refit please? I've done a search but that returns engine subframe related activities topic. I hope what I need to do isn't as complex!! Cheers Quote Share this post Link to post Share on other sites
bruny 0 Posted May 2, 2009 Not a five minute job but not too serious. Remove front bumper- 4 bolts through to chassis, disconnect lights etc. arch liners removed, splitter bracket removed remove slam panel- self explanatory when you get to it. Remove radiator- disconnect power steering cooling pipe fastened to cross member Prop up the engine for removal of front engine mount Remove cross member and replace with new one Basically covers it, sounds easy enough, good luck :D Quote Share this post Link to post Share on other sites
MARLBORO_LITE 0 Posted May 2, 2009 Nice one bruny! Thanks very much, nothing there to frighten me off attempting it!! Quote Share this post Link to post Share on other sites
