2_Door_fun 0 Posted May 21, 2009 As it sez.. What does it do all I know is its a 1.2bar pressure switch. ta muchly Rob Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 21, 2009 What car - G60? Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted May 21, 2009 Sorry yes.. 1991 G60. just purchased a new VAG Blue Temp sensor and on the drawing on screen was the image of it.. Was wondering what it did being as I am having over fueling problems. Quote Share this post Link to post Share on other sites
WigsVR6 0 Posted May 21, 2009 sorry no help but i love your avatar picture cant get enough of it good luck with your problems though Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted May 21, 2009 Cheers bud.. Always helps to have a willing lady in yr life to pose... :norty: done many of em some printed well big on canvas n stuff. Pleanty of poses :censored: Cheers Rob Quote Share this post Link to post Share on other sites
WigsVR6 0 Posted May 22, 2009 :offtopic: but legs are my weakness and they look great!! Quote Share this post Link to post Share on other sites
Riley 0 Posted May 23, 2009 If the pressure drops after running the car, the switch makes the pump run. Though it should only come on if the fan is also running at the same time. Quote Share this post Link to post Share on other sites
Yandards 0 Posted May 24, 2009 If the pressure drops after running the car, the switch makes the pump run. Though it should only come on if the fan is also running at the same time. Just to elaborate on that a little more. The pressure switch will only come in play after the engine has been run and switched off and the thermo switch (little brass switch on the fuel rail to manifold bracket) has a temperature of above 90 deg C. Then the coolant fan will operate at the 1st stage, after 2 mins has elapsed and providing the fuel pressure switch has a pressure of above 1.2bar then the fuel pump will run to maintain fuel pressure in the system. The reason for the time delay of 2 minutes and the requirement for 1.2bar of pressure is if the fuel system has a leak the pump will not be filling the hot engine bay with fuel. The maximum running time for the both the fan and the fuel pump is 10 minutes, all these functions and timing for the fan and pump are controlled by a pair of relays - at position 13 and 14 above the fusebox. Quote Share this post Link to post Share on other sites
