dutchboy 0 Posted June 8, 2009 just wondering which version of vag com and which leads I need for a 1993 2.0 16v? Cheers for any help Quote Share this post Link to post Share on other sites
Toad 0 Posted June 8, 2009 Lift the gear lever surround and you'll see the connectors. You probably need the 2x2 connector, but don't expect to find any engine fault codes, just ABS ones on the 16v. Quote Share this post Link to post Share on other sites
dutchboy 0 Posted June 8, 2009 really? so I wont be able to reset the ECU with it? Quote Share this post Link to post Share on other sites
Toad 0 Posted June 8, 2009 I don't think there is an ECU reset for the 16v... There is one for the VR, but that's a far more complex ECU. What's the issue?? Quote Share this post Link to post Share on other sites
dutchboy 0 Posted June 8, 2009 basically I've messed with the mixture screw and confused everything!!! Quote Share this post Link to post Share on other sites
VR6 0 Posted June 8, 2009 Think you'll have to 'unmess' with the mixture screw - there isn't a magical fix unfortunately :( Quote Share this post Link to post Share on other sites
dutchboy 0 Posted June 9, 2009 hmm, well to help me I know I need to take a reading from the plug on the side of the metering head but cannot find out what that reading should be!! Can anyone help? Quote Share this post Link to post Share on other sites
corradophil 3 Posted June 9, 2009 Disconnect the breather from the front of the block. Disconnect the small hose going to the valve at the rear of the airbox. This is approx 5mm dia, and you will need to disconnect the electrical connection to get easier access. Once the hose is disconnected, re-connect the electrical connection. Connect an ammeter in series with the differential pressure regulator (electrical connection on the engine side of the airbox) Switch ignition on, the current should be between 90mA and 110mA. If it is a negative reading, swap the +ve and -ve ammeter connections around to get a +ve reading. Start the engine and alow to settle for 30-60 secs. The ammeter reading should be fluctuating. The allowable range of the fluctuation is 0-5mA. If the ammeter reads out of this range adjust the mixture screw to get it within the acceptable range. Adjust a little at a time and wait for 30-60 secs for the ammeter reading to settle. As for vagcom, I think I use Version 406 on my 93 2.0 16v. Do a search for it, I know RW1 posted the correct info for connecting vagcom to the 9A corrado. Quote Share this post Link to post Share on other sites
dutchboy 0 Posted June 9, 2009 thats great info. I'm gonna try it tonight. so it needs to be around 100mA then? Quote Share this post Link to post Share on other sites
corradophil 3 Posted June 9, 2009 100mA with ignition on, but engine not running, if negative swap positive and negative cables on around on meter to pass the current the in the opposite direction. Then start the engine and adjust mixture until it fluctuates between 0-5mA whilst engine is running. Once complete, don't forget to connect the hoses you disconnected. Quote Share this post Link to post Share on other sites
dutchboy 0 Posted June 9, 2009 I'm having trouble finding which connector to connect to?!?!?!?! Looking from the top, you have two either side of the airbox near to the front of the car, then two ether side at the rear of the box which connect into two valve type things joined by a pipe. Where do you take the reading from? Also do you just take the reading from the connector or from where it plugs in? Sorry for the vague sounding questions but I really need to know. Cheers for all the help guys!!!!! Quote Share this post Link to post Share on other sites
corradophil 3 Posted June 10, 2009 If you can post a photo of the airbox, I will download and circle the connections and post it up for you. You need to measure current (Amps) which means the meter has to be in line between the cable and plug. Quote Share this post Link to post Share on other sites
dutchboy 0 Posted June 10, 2009 i thought so, i've tried it and cannot get a reading. Is there an adaptor plug for doing this sort of thing? or is it a case of just trapping some wire in there? cheers Quote Share this post Link to post Share on other sites
corradophil 3 Posted June 10, 2009 I had a couple of old plugs which are the same, so I made up a test lead for carrying out this set up. Quote Share this post Link to post Share on other sites
RW1 0 Posted June 13, 2009 "I don't think there is an ECU reset for the 16v... There is one for the VR, but that's a far more complex ECU." No reset procedure required. Put into "Basic Settings", Select Group 00 Blip the throttle to 3,000 rpm and leave idling for 1 minute. Check field position 9 has got a value of 5 in it. Quote Share this post Link to post Share on other sites
dutchboy 0 Posted June 14, 2009 and then thats it? cheers!!! when i run a basic scan it comes back with nothing. is that right? Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted June 26, 2009 Without trying to hi-jack this thread what will i be able to read using Vagcom on my '92 16v and would i need to buy this adaptor for the vagcom cable? http://cgi.ebay.co.uk/2X2-to-16-Pin-Adapter-Cable-VAG-COM-OBD2-OBD-2-VW-AUDI_W0QQitemZ220442066104QQcmdZViewItemQQptZUK_Diagnostic_Tools_Equipment?hash=item33535efcb8&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1689|240%3A1318|301%3A1|293%3A1|294%3A50 Quote Share this post Link to post Share on other sites
millerman 0 Posted June 26, 2009 yes thats looks like the one the obd connection had a large d shape connection Quote Share this post Link to post Share on other sites
andreiz2132 0 Posted August 17, 2009 I read 120mA on my differential pressure regulator. What does this mean? Quote Share this post Link to post Share on other sites
kevn 0 Posted August 9, 2010 Will VCDS lite do this? Quote Share this post Link to post Share on other sites
