Kempy 0 Posted June 17, 2009 I have broken my controls for sure, I would like to get them fixed is this possible? firstly I cant get them from the centre console which doesnt help, Is anybody up for having a go mending mine? or selling me some cheap ones. They all seem to get snapped up quickly on the breaking cars Quote Share this post Link to post Share on other sites
VR6 0 Posted June 17, 2009 They're easy enough to fix - what's the problem with removing them/repairing yourself? Quote Share this post Link to post Share on other sites
Kempy 0 Posted June 17, 2009 i cant get them from the car :lol: how do you get the cables off it? Quote Share this post Link to post Share on other sites
The_Dude 0 Posted June 17, 2009 New or old interior? Quote Share this post Link to post Share on other sites
The_Dude 0 Posted June 17, 2009 unscrew the four screws after taking off the fascia plate, and push the left side of the heater box into the dash..this should mean that the other side will now be loose and free to pop out from behind the tabs. it is a bit of a squeeze, but should work. the cables will pop off the ends of the metal arms, maybe with the help of a screwdriver. Quote Share this post Link to post Share on other sites
Kempy 0 Posted June 17, 2009 I bet the cables are hard to get back on Quote Share this post Link to post Share on other sites
The_Dude 0 Posted June 17, 2009 in a word, yes. in many words, its a complete fekking nightmare! making sure everything works, that the cables are still on the ends of the tabs, that you have not pulled on them as you put it back in opening up some vents, and then trying to get the control box back in the dash without anything falling off..... :brickwall: oh yeah and getting the cables off without snapping the holding tabs is very hard indeed. i was really careful and still ended up snapping one. Quote Share this post Link to post Share on other sites
vr6storm 0 Posted June 17, 2009 also make sure that you keep the rotary dials in the correct order,as although they will fit each other they won't rotate to the same degrees(pardon the pun) Quote Share this post Link to post Share on other sites
Kempy 0 Posted June 17, 2009 still cant do it. whats the method for getting the springy loaded bits out, the electric wires are easy but the 3 metal control bit I dont know what parts to move before I brake something.. :help: Quote Share this post Link to post Share on other sites
The_Dude 0 Posted June 17, 2009 can you take a pic? Quote Share this post Link to post Share on other sites
The_Dude 0 Posted June 17, 2009 do you mean the bendy metal tabs that hold the cables onto the box? they will lever off from the bottom iirc, but be gentle. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 17, 2009 the bit on the right has to come off first, just lever it upwards from under neath, its just a metal clip, iirc it takes some force toget off Quote Share this post Link to post Share on other sites
Kempy 0 Posted June 17, 2009 I got it out :clap: :clap: .. now I got to find out the problem..Its something to do with the 4 speed switch, any ideas? I have changed the thermo fuse and the blower motor also so far. I turned the switch through 360 degrees, what bit could be broke? ta Quote Share this post Link to post Share on other sites
The_Dude 0 Posted June 17, 2009 Check the connections on the back of the dial to see if contact is being made at al 4 stages. Mine works on 3 and 4, sometimes 2 and never 1, but i can't be arsed to take it out again! Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 17, 2009 i took mine out but now its all back together it doesn't light up anymore Quote Share this post Link to post Share on other sites
Kempy 0 Posted June 17, 2009 looking at it, the cooper appears bent, but I could see that when it was in the car, whoops. try and get a pic up Quote Share this post Link to post Share on other sites
Kempy 0 Posted June 17, 2009 looks like the cooper is bent, but im not sure if this is the problem, I could see this when it was in the car :lol: Quote Share this post Link to post Share on other sites
vornwend 0 Posted June 17, 2009 Looks like the bent copper is the problem (sorry officer). That was the problem with mine a while ago. I messed about with it so much that I snapped it the end :( Managed to get a replacement from the scrappies. It took ages to get it set so that there was a good contact on all 4 settings. IIRC you also need to be remember which dial goes on which position because although they look the same there is a subtle difference :? Quote Share this post Link to post Share on other sites
Kempy 0 Posted June 17, 2009 does the moving part go under or on top? Quote Share this post Link to post Share on other sites
vornwend 0 Posted June 17, 2009 does the moving part go under or on top? Pretty sure it was on top Quote Share this post Link to post Share on other sites
Kempy 0 Posted June 17, 2009 hmm still cant get nout to work.1 fuse is ok, blower motor I took from my other rado, early interior (would this make a difference?) but it was working. I think I will try to put my old motor in with the thermal fuse fitted. and go from there, the blower wires may differ some how. What else could it be Quote Share this post Link to post Share on other sites
RaddoMan 0 Posted June 17, 2009 its that , you need to get it to make both sides Quote Share this post Link to post Share on other sites
