mort1414
crack pipe replacement
just spent the last 2 hours with the rac due to my crack pipe so im going to be changing it soon as i no that theres 2 littles hoses down there that im goin to change but should i change anything else seeing as iv got the bumper off
cheers morten
worth checking the thermostat housing while your there, its quite common for them to crack.
i found out the hard way that fixing one leaks tends to lead to the next weakest link breaking, especially if its all old plastic parts.
Theres also the main water pump in that area, but i found that hard to get to and involved lifting the engine up or down
quite simply take the fans off and then remove the rad (drain the system first :wave: )
and also remove the grill then you have access to the crack pipe and like said above prob a good idea to change the thermostat housing and stat while your at it
took me an afternoon .
