Mawrick 0 Posted June 21, 2009 Anyone know if there is much "stress" on the bolts that holds that "rubber-ball" thingy inside the cup under the front engine mount?. When taking mine of, one of the bolts broke (noticed a small "crack" going inside the bolt), and therefor I have to weld in a new one, so I'm just wondering if there is much force being put down on the cup itself, or if it would also be safe to drive only with 2 bolts in place?. Quote Share this post Link to post Share on other sites
pete_griff 0 Posted June 21, 2009 Anyone know if there is much "stress" on the bolts that holds that "rubber-ball" thingy inside the cup under the front engine mount?. When taking mine of, one of the bolts broke (noticed a small "crack" going inside the bolt), and therefor I have to weld in a new one, so I'm just wondering if there is much force being put down on the cup itself, or if it would also be safe to drive only with 2 bolts in place?. from takig mine off, i would say that there would be little/no stress on the actual cap itself... it's the crossmember itself that takes all the strain, the cap is there just as a precautionary mesaure from what i could see... i's the main big bolt going up through the centre of the engine mount that you want to worry about. don't take it s gospe - but personally i can't see any problems wih driving it like that Quote Share this post Link to post Share on other sites
Mawrick 0 Posted June 21, 2009 Ok, gona get it fixed by welding in a new bolt, but was just wondering if that would be ok, and I guess it should be....:) Cheers! Quote Share this post Link to post Share on other sites
