GreasyWeasel 0 Posted June 25, 2009 Ladies and gents. While doing all the usual weekly checks under the hood today I noticed that there was a wire floating loose in the engine bay. It has a connector on the end and I could see where I'm pretty sure it's come off from, but before I go re-attaching it can someone tell me what it's function is as it would be nice to know for future reference, and what it might have done to the old girl while it's been off. The picture shows, as you look at the engine from the front, the front right hand side behind the radiator. Any help please? Weasel.engine.JPG[/attachment:1zsl8not] Quote Share this post Link to post Share on other sites
markrtw 0 Posted June 26, 2009 A wire drops down from the injector part of the loom and plugs into this on mine. Quote Share this post Link to post Share on other sites
GreasyWeasel 0 Posted June 26, 2009 How it be affecting the car not being attached? The wire shoots off a larger wire bundle that disappears off behind the engine somewhere so I've no idea what it's attached to. Quote Share this post Link to post Share on other sites
redwoodkp 0 Posted June 26, 2009 The only thing I can think of in that area (that I know about) is the reverse light connector?? Check your reverse lights are coming on when in gear :) Quote Share this post Link to post Share on other sites
markrtw 0 Posted June 26, 2009 I don't think you will find the reversing light switch in the end of the inlet manifold, though knowing these cars they often do defy logic. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 26, 2009 Plug it back in immediately (to the sensor arrowed). The ECU needs it to determine intake air temperature. Quote Share this post Link to post Share on other sites
GreasyWeasel 0 Posted June 27, 2009 I'd plugged it back in once I'd posted this on here as I figured that would be screwing something up, and even though I'm sure it's phycosymatic she does seem to be running better. Cheers chaps. Weasel Quote Share this post Link to post Share on other sites
redwoodkp 0 Posted June 28, 2009 I don't think you will find the reversing light switch in the end of the inlet manifold, though knowing these cars they often do defy logic. Ha ha I couldnt have been further away if I had just guessed!! :nuts: Quote Share this post Link to post Share on other sites
