soother
What size disc can I fit under wheels
Can any one tell me what size disc I can fit under a set of Porsche D90 16'' with Brembo calipers.
Thanks for any help.
afaik, the biggest disc you can run under 16's is going to be the 312mm conversion. i don't think they will fit under all 16" wheels, but they will fit under most.
the 312's aren't a bad setup, but it depends on how fst your car is and how hard you drive it as to what setup you go for.
check out corrado vr6 turbo's thread - he runs 312mm discs, but with tar-ox 6-pots. that said though, i think he has to run 17's due to the size of the calipers; he also has to run wheels spacers (albeit very thin ones) to get the spoke clearance
G60 discs with 4 pots,they go under a 15" wheel with ease,if i could get a cheap 305mm disc iam sure i could get that to fit with 15"wheel,i dont want to buy a good set in case iam wrong and they dont fit
Im soon to be running D90's and iv got 4pot Brembos with 305mm Discs and they fit fine! :D
excuse my ignorance,are D90s 15" or 16"
