CoxyLaad 0 Posted July 9, 2009 Well as a few of you are doing 4wd conversions on their corrados now, and most are away that fitting the mk2 syncro rear axle to the corrado incurs a lot of negative camber, I have set about putting together some kits to allow proper camber and toe adjustment for said syncro axle. The kit consists of a number of channelled slotted plates that are welded to the swing arm pivot points, and some replacement eccentric bolts. just wondered if there would be much interest in this? I have them for my car now, and will be fitting it up in the next month or so I would say. Price is going to be round the 150 mark when you take into consideration the raw material, machining time and bolts. Just trying to gauge some interest. Quote Share this post Link to post Share on other sites
