steveo29 0 Posted July 18, 2009 ive always thought my g60 was a bit dull and sluggish some time ago while messing around with something i drove it with the o2 undone..it pretty much transformed the car , much more peppy and revvy , more torque steer etc so im confident in saying it drives much nicer with it unplugged ive sinse tried a new bosch sensor , drives identical to the other one all service parts are good , everything checks out as i believe it should do any ideas people ? Quote Share this post Link to post Share on other sites
Riley 0 Posted July 19, 2009 Hi mate, As per pm i can't unplug my lambda without removing it from the exhaust and doing a recalibration, as its a wideband that feeds the original ecu along with the gauge... First port of call would be the usual earth checks...The ones on the side of the head water flange (or rocker cover on earlier motors) are important as its where a few meet for the c/o pot, throttle switches etc. Obviously check the main box one, and around the battery tray. If they are all clean and looking good then id do a cheque for resistance across the lambda signal. If you pull the rubber boot off the ecu plug (best remove it first for a good look at the pin numbers) then you should see a purple at pin number 2. Thats the lambda signal wire. If you stick your test meter on ohms and put one point in beside this wire (with loom plugged in) and your other point to the battery earth. Just see what sort of resistance you get with ignition on/off and also at full running temp while holding the throttle open slightly. If you want to check individual eaths back to the ecu, then pin 6 is the earth for the lambda (sort of), c/o pot, throttle switches, hall sender. Just have your test probe in pin 6 while using the other probe at each sender/sensor earth. Neil. Quote Share this post Link to post Share on other sites
steveo29 0 Posted July 19, 2009 cheers for that ive checked the o2 signal down by the actual sensor is there any reason why i cant jam a wire in the ecu plug to make sure the signal is getting to the ecu? then again i spose it is as otherwise unplugging it wouldnt change anything Quote Share this post Link to post Share on other sites
steveo29 0 Posted August 17, 2009 ive whacked up the co pot to 700ohms...seems to drive much better now with the o2 connected Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 17, 2009 Hmmm - does the wideband say it's stoich? Quote Share this post Link to post Share on other sites
steveo29 0 Posted August 18, 2009 not tried it aint really sure what wideband should say ...cant seem to get a expert answer Quote Share this post Link to post Share on other sites
