mistrall
how to remove clock circuit bord?
hi guys, were trying to find out the rpm wire from the back of the clocks - as its not standard i think the only way were going to do this is to take the clocks apart and trace it to the wire - any idea how to get the circuit board out of the clocks?
you gotta lift off the 3 white plastic bits under the dials, the dials have 2 flat head screws. once the dials are off the 6 gold/brass phillips on the cicuit board need to be remmoved. once they are off pull off the plug that connects the board to the bulbs on the outer case. then the board will be loose, Its a bit of a fiddle but it helps to turn over the case, then push the black connector out from the case might need a flathead to help it out.
YOu then have the board free from the case, on the under side you'll see you need tiny torx screws to remove the LCD/clock and other bits.
think this should help
