zaidi
VR6 Turbo what specs
Hi guys, dont know much about turbo specs.
But need to know if this turbo spec is any good for the 2.9VR6.
T3T4 T04E .50AR and .63 hotside
Basically need to know at what RPM will this turbo start spooling, and when will it choke, and how much psi it would produce at say 4k rpm.
Also considering just the aspect ratio and stuff, If this is a rubbish turbo for the VR6, what specification would be best for reliable 300whp on a vr6.
Im confused because there are so many different specs for the T3T4 turbo, how do you go about choosing the right one. Basically im trying to source the turbo and stuff myself for the VR6.
The forced induction VR6 thread would probably be best for this information.
There's been a few comments on turbo suitability already, have you tried searching?
I have checked it, there isnt much about turbo suitability.
Anyone out there who can help!
Yes that turbo will work and is quite a popular choice for the VR6. Full boosts quite early, around 3000rpm, but the 0.63 hotside and small turbine wheel will choke the top end. For your power goals, I'd say that is ideal.
What about the other stuff? The turbo is just one part of a turbo conversion. What manifold are you using?
