NeilG60 0 Posted August 16, 2009 After having my Corrado in bits for a short while im now putting it back together but now my drivers side window wont close!! I havent actually done anything to the window itself although the door card has been off at some stage so nothings been unplugged/plugged in incorrectly!! When i press the switch I can hear a clicking sound as it somethings trying to do something but unfortunately its not closing!! Can anyone help?! :) Quote Share this post Link to post Share on other sites
STU175 0 Posted August 16, 2009 first thing i would do is whip off the door card see if you have volts to motor when pressing button. do this using multimeter or bulb wiith two wires can be used :D if no volts check fuse/wiring back to fuse board if you have power and doesnt try to move it could be motor gone. if it trys to move but doesnt could be broken mech. hope this helps .i do have mech and motor if needed? stu Quote Share this post Link to post Share on other sites
