James. 9 Posted August 19, 2009 Hi all Followed the wonderful thermal fuse replacement guide as the heaters were only blowing/heating on setting number 4. Heaters/blowers now work on settings 1, 2, 3 (windows) but not on number 4 ! Any clues and/or suggestions ? NB: When I removed the lower dash cowling, I found when removed, the thermal fuse to be located higher up the ducting and behind the glovebox. 92 VR6 if it helps. Quote Share this post Link to post Share on other sites
Oliver2 0 Posted August 27, 2009 This happened to me, I fixed the fuse and then this happened. I found out its the actual contact strip the dial for the speed setting uses behind the plastic dial, youll see it if you pull it off. I tweeked it by bending the contact strip in different places with some pliers till they all came in contact on each speed and it worked! bit fiddly and irritating though. A new heater dial console went for £80 on ebay the other day htough so probably worth the effort! Bit weird it happened to wear out at the same time the thermal fuse went though? I didn't get it, must have blown the fuse with intermittent contact or something, beats me, Raddos :cuckoo: M Quote Share this post Link to post Share on other sites
