bad-vw-boy
screw on throttle body????
whats the screw on the throttle body as mine seems to be all the way out , how far should it be screwed in? ....its the on on the side facing the front of the engine...by the way i have a 1.8 16v......cheers :)
if you're planning on messing with the idle screw then you'll need to do it whilst monitoring the fuel mixture also.
you'll need an exhaust gas analyser
is there actually a problem?!
if ur not sure what your doing i'd take it to a garage for 5 mins rather than fiddling with it urself :salute:
