C.P 0 Posted August 25, 2009 I went to change my rear discs and pads on an 89 but found that i couldn't get the calliper back over the new pads, turns out i was using the thicker ones so i got the 15mm thick pads which are the correct ones, but still can't get the calliper over. I'm not one for buying fancy tools for simple jobs, so i've always used a massive G clamp to wind back the pistons which has worked a treat over the years, but these callipers wont budge any further! Are these callipers knackered or do i NEED the proper wind back tool to get them back far enough? Quote Share this post Link to post Share on other sites
millerman 0 Posted August 25, 2009 you need a wind back tool Quote Share this post Link to post Share on other sites
StuartFZR400 0 Posted August 27, 2009 if you're tight like me, yu can make one. Used a box spanner and cut back, leaving two dimples - was pure luck I had the correct diameter. You've got to press as you wind back. The windback tool does the job for you and is much easier - looks a bit like the one below; ask in the shop. If its really stiff, you might suspect a seal. Quote Share this post Link to post Share on other sites
C.P 0 Posted August 27, 2009 cool, i'll get a shot of some from my mates work. On the sly ;) Quote Share this post Link to post Share on other sites
Mark_Storm 0 Posted August 28, 2009 Its well worth £18. Takes freckin ages without, takes 2 minutes with one Quote Share this post Link to post Share on other sites
