rookierod
vagcom
hi looking to get vagcom set up, for that dreaded day when have problems. i am a bit unsure thou. has tryed reading up but still cant find out, do i need the usb-16pin and the 16pin-2x2 cable? for my kreg 2.0 16v? what other things apart from fault dia can you do or is this all it does? thats ian
i would find it useful if someone could run thru everything thats needed if possible :)
i understand where the interface is but is it a simple case of laptop, software & leads?
yes but do i need to get the usb-16pin cable and also the 2x2 adaptor or not?
If it has the 2x2 connector in the car then you will need the adaptor to plug into the 16 pin lead. But when i bought mine from ebay it came with the adaptor anyway.
