culshaw
wheel bearings
how hard are they to fit, where's the best place to get them (vag, gsf etc)
ETKA says part 357 498 625 B @ £76.23? for qty of 2 but i'm new to ETKA so is that right?
That part above is for fronts on base suspension models (not VR6) and it's only worth buying genuine VW ones.
They are £21 +vat from TPS and you need a 10 tonne press to fit - ie take the hub carrier off and take to a garage.
You will also need a full camber setup doing after changing them.
Also worth getting the hubs blasted and painted while they are off if you have time -
thanks,
you got a link to TPS i got no clue (the parts store??)
have you got the rear bearings vw part number? might just get them all at once
