Kaktus 0 Posted September 7, 2009 Hi guys The fuel pump in the Corrado doesn't "prime" anymore so the car won't start. I replaced the pump about a year ago with a new Bosch unit so i doubt it's the pump itself. What number relay and fuse can i check? Any other common problems i can have a look at before looking at a new pump.? I'm almost 100% sure it's electrical and not the pump, as this is the second time in 3 weeks the pump just mysteriously stopped working. The car is a '89 16v KR. Ta :tongue: Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 7, 2009 can't remember the number relay but it's the small blue one with two f**k off large connection pins when you pull it out (I guess it takes a fair current) and a couple of much smaller pins IIRC. OK, so the parts list says location 12 and the part number is 191906383C - same on all corrados Quote Share this post Link to post Share on other sites
Kaktus 0 Posted September 7, 2009 Ta for the quick reply David. I'll have a look when i'm at home again! :notworthy: Quote Share this post Link to post Share on other sites
Fulltimejunglist 0 Posted January 5, 2011 you get this sorted in the end? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted January 5, 2011 doesn't the inside face of the fusebox lid tell you which relays / fuses are for which things? Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 6, 2011 doesn't the inside face of the fusebox lid tell you which relays / fuses are for which things? just the fuse list I think Quote Share this post Link to post Share on other sites
Fulltimejunglist 0 Posted January 6, 2011 yea jsut the fuses, i think the pump fuse is no 13 but i may be wrong.... I think i may be having the same problem, starts goes to 1500 rpm then dies.... Quote Share this post Link to post Share on other sites
