diarmaid16 1 Posted September 14, 2009 Hey all, My 16v just had its test recently and failed. It needs a steering knuckle and the handbrake isn't pulling on the right hand side. Just wondering is the knuckle an awkward job and if anyone knows what would sort the handbrake. Seized caliper or handbrake adjustment? Any help appreciated. Cheers! Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 14, 2009 I guess you mean track rod end, they're pretty easy, providing the old one isn't siezed on solid, just need a bal ljoint separator ideally. The brakes will more than likely be a siezed hand brake mechanism in the caliper, they're all prone to this over time. Quote Share this post Link to post Share on other sites
Reggit 0 Posted September 14, 2009 A steering knuckle could also be a U/J on the column instead of a track rod end. Quote Share this post Link to post Share on other sites
millerman 0 Posted September 14, 2009 just done a steering UJ on ryan_16v on here and its a pain in the arse to get to and give you back ache and i recomend to let the car cool right down as you will burn your self on the down pipe and manifold :D Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted September 14, 2009 Ya, thats the joint I'm on about. I hear theyre not the easiest on golfs and was told theyre they might be the same. So what should I do with the brakes? Quote Share this post Link to post Share on other sites
KipVR 1 Posted September 14, 2009 Take the rear caliper off and you'll see the lever the handbrake pulls, you probably need to free it up. Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted September 14, 2009 Thanks for that! Quote Share this post Link to post Share on other sites
