odub
9a running issues poss ecu related
I've had running problems on my 2.0 16v 9a. The car has been well gone through with all the timing checked and correct and all new engine sensors bar the hall sender. The symptoms are that under normal, gentle driving it feels very slow to pick up and hesitant when cruising at a constant speed but clears immediately as soon as I get my foot right down. Last night I disconnected the battery and left if for about 30 mins. After reconnecting it started and ran fine and still fine this morning going to work. Could my problem lie in my ecu or would this suggest something else? Thanks
It has had a new lamda and I was thinking about it down the pub last night with it being a pattern part and reading a while back that they can misbehave. I can't figure how it can run fine at the moment though. Also which make lamda should I fit?
