pt_corrado 0 Posted September 28, 2009 Hi there. Just to ask witch head gasket and\or cylinderhead gasket kit are better for the PG engine? hope that the G60 owner gurus can help me with this :norty: . best regards Quote Share this post Link to post Share on other sites
G60_Marc 0 Posted September 28, 2009 Personally ive always used elring gasket sets. Quote Share this post Link to post Share on other sites
pt_corrado 0 Posted September 28, 2009 Personally ive always used elring gasket sets. do you use metal headgasket in your g60? Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted September 29, 2009 Personally ive always used elring gasket sets. do you use metal headgasket in your g60?[/quote:4lrskbmg] they are stronger. I did/do. Quote Share this post Link to post Share on other sites
G60_Marc 0 Posted September 29, 2009 Personally ive always used elring gasket sets. do you use metal headgasket in your g60?[/quote:3cpq0uvt] The Elring set i use comes with a multi layer steel headgasket, valve stem seals, cam shaft seal, 2 different inlet manifold gaskets, 2 different exhaust gaskets, exhaust manifold to downpipe multi layer steel gasket and a rubber camshaft cover gasket. Bought my set from here Quote Share this post Link to post Share on other sites
Yandards 0 Posted September 29, 2009 Elring is OE VW supplier so go with them. Quote Share this post Link to post Share on other sites
pt_corrado 0 Posted September 29, 2009 i saw in the bar tek site some parts, any of you know if they head gasket kit are good? thanks for your help regards Quote Share this post Link to post Share on other sites
