aussieveedub
Fan not switching off
Hi i am looking for help as i have just imported a corrado G60 88 to Australia well its on the ship still Nov and the guy who done all the leg work buying it said it kept getting a flat battery he later noticed the fan remained on,i know nothing about cars but do have a VW specialist nearby but i need to get parts sent over before it arrives.Any tips as he said it could be the fan switch.Cheers
I had this once before on an Audi. The thermoswitch in the radiator had packed up. I replaced it and had no further issues.
It's more likely to be the fan run on switch, if the cable is earthing against the block (well, anything really) or the switch is faulty then the fan will stay on.
This is the sensor that keeps the fan running when you switch the engine off, for up to 10 minutes I believe, to stop the fuel evaporating in the fuel lines.
Pic of the valver one in THIS thread
Similar problem on my 1.8 16v. The switch on the radiator was covered in white corrosion. Cleaned it all up, a bit of vaseline and all has ben well since.
