vwdeviant
ABS Fault... Relays? some guidence please?
Been having ABS issues on my 92 9a, Valver... so had it Vag-com'd .. cleared down a load of fault codes and than took it for a run.. got the following:
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
16-00 - Signal Outside Specifications
Looking at Google seems to run the whole range from fuses to pumps to control units!
So what should I be looking at?
Which Relays? (cheapest fix)
Wiring, (hate wiring)
Control unit, (ouch)
or replacing the whole pump? (walet screems)
:shrug: :scratch:
I'd start with getting the sensors outta the hubs and giving them a good clean, be prepared to struggle to get them out, but that'll hopefully clear the signal fault.
The hydraulic pump issue is anyones guess I suppose, but I agree, it doesn't sound promising... :gag:
new pump !!!!! :( vagcom would tell you if the sensors were at fault 2nd hand abs pumps can be had for around £20-30 on ebay
so not really a major worry
Sensors and cages are all ok... replaced rear cages and cleaned up all sensors a while ago...
Anyone know which relays to replace on a 9a??
Does no one know which are the ABS relays on a 9a?? :(
May save me £60+ on another ECU... and then a pump if that doesn't work...
Relays behind the glove box....
How old is the fluid?
Have you checked the ABS ECU for water damage ? - I'd do this before anything else...
Fluid ws changed in April (new discs/pads) and ecu was checked at the same time.. got no white/green fuzz on the connectors...
Taken me this long to get it VAG-Com'd
Would really like this sorted ASAP as the missus is due in 6 weeks and want it done before then as she'll be using the car after JR's born (only car)
Might be worth borrowing an ECU just to rule it out...
Could also be something like a bad battery or alternator / regulator
Also maybe worth cleaning / re-seating all the plugs and connections to the ABS pump / Valve block.
Eveything cleaned and re-seated, alternator and battery's puting out plenty of juice (13.6 from memory).
So next port of call is the ABS relays... anyone know where they are in a 9a? Assuming the one's in the bay itself?? :shrug:
