lilfuzzer
engine block clean up?
had a search and few products looked at but was after some specific advice.
the block i have has quite a bit of surface rust what is the opinion of those (you) in the know should I use on the the block to get rid of it. I was going to use a wire wheel on a drill or angle grinder but if their is any left embedded what is the best advice?
Was going to paint the block afterwards a mate has painted with some ford paint that he got cant remember nme aat the mo so any ideas from thise on here?
many thanks guys!
  millerman said:
just scrape it off mate and wire wheel and brush and some elbow greese is always good :D
Cheers bud is there anything I should treat it with before some kind of paint?
i have just done mine and used various sized wire attachments on a drill, and painted directly onto the clean metal with smooth black hammerite. i did a mk2 golf like this years ago and it still looked great some 5 years later.
Yeah I was wanting black so hammerite will be cool if use that prob?
cause chaps as need to get this done before the engine rebuild which I have been told need to be done before easter(maybe couple years time). was hoping not next year but needs to be done for then :lol:
