ryan_16v
Alternator.??
Will other corrado alternators fit my 1.8 kr ie 2lt 16v / g60 etc etc
you need a 16v specific one as the mounting bracket is 16v specific, a 65 or 90 amp oe will do though, same 90Amp one on the equivalent age passat, 16v mk3 golf is different again though as that uses a serpentine drive belt
You may find like i did that the pulley it comes with is different (mine was an upgrade to 90amp from an independent parts place) but they should be swapable.
