eugopnosaj 0 Posted November 5, 2009 Ok got a few questions, i should have taken 'pre-take apart' photos but stupidly didnt now ive got a few things that are hanging around: climatronic wiring-Golf from May 01.pdf003.jpg[/attachment:24ib1333] I have forgotten the order for the injectors and cannot find it anywhere, i think ive got it right (based on length of pipe) but obviously need them to be in the right order if anyone can help passat climatronic wiring diags.pdf004.jpg[/attachment:24ib1333] What is this and where does it go? If it attachs on the brown cable in the picture below where do i fix it? It doesn't fit on the bolt of the rocker cover nearest the cable... 2.8l 24v Climatronic system.pdf005.jpg[/attachment:24ib1333] Does the brown cable (red arrow) go on the above (sensor im assuming)? If not where does it go? 009.jpg[/attachment:24ib1333] Does the green cable (red arrow) go on the sensor (green arrow) Also where is the ambient (outside) temperature sensor? Ive tried looking in my Bentley manual but it doesnt show anything. Also it doesnt even come up on my display as it being an option...its a 92 2.0l valver Thanks! J Quote Share this post Link to post Share on other sites
Toad 0 Posted November 5, 2009 The pipes are shaped so they should only fit one way, but they shouldn't actually matter as far as I understand the K/KE-Jet system. The sensor in your hand does connect to that wire, and clamps to the front of the rocker cover. That does look like the right wire for the oil temp sensor. The ambient air temp sensor plugs into the lower grille in the bumper. Driver side. Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted November 5, 2009 Yeah, the pipes seems to fit 'nicely' this way without them being strained so i guess they're probably right. I know the cables seem fairly obvious, being in the same location etc but i'd rather be certain of where they go and not cause any problems! :) Thanks, J Quote Share this post Link to post Share on other sites
