ShabC
possable to run g60 witout charger?
hi was wondering if it possable to drive my c without the charger is there some sort of thing to do that, its just cause i need to send the charger off but i still need to drive my care. thanks
Hi mate,
Yep. If you speak with any of the suppliers, they can supply you with a shorter belt to use with no charger. You will need to make up a little piping to the airbox too.
Neil.
i thought there was something you can replace the charger with??
Just piping airbox to intercooler.
And you need to block off the oil line feed too .
