robtalbott 0 Posted November 22, 2009 about a week ago the power steering (i assume) started squealing a bit on full lock (similar sound to a fan belt on its way out). this has now degraded rapidly to the point which it squeals whenever you try and steer either direction at very low speeds or standstill, and the steering goes VERY heavy and jerky. this happen to anyone else? diagnosis/easy to fix? also, would you continue to drive the car in this condition (is it likely to cause more damage)? Quote Share this post Link to post Share on other sites
mikkijayne 0 Posted November 22, 2009 Just put a new belt on :) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 22, 2009 Also check to see if you are missing the belt cover as this helps keep water away from it Quote Share this post Link to post Share on other sites
volksworld13 0 Posted November 22, 2009 check your powersteering level and condition of oil, check belt condition and adjustment, :) Quote Share this post Link to post Share on other sites
millerman 0 Posted November 22, 2009 check your powersteering level and condition of oil, check belt condition and adjustment, :) same as check the fluid sounds like you may have a leak Quote Share this post Link to post Share on other sites
Diamond Hell 0 Posted November 23, 2009 Also check that the pump's not seizing, due to failing bearings especially if there's a bit of leakage around the pulley. Quote Share this post Link to post Share on other sites
krnau 0 Posted November 23, 2009 it happened twice to me the 1st: broken PAS pipe, leak, no fluid the 2nd: PAS belt not in tension. good luck Quote Share this post Link to post Share on other sites
robtalbott 0 Posted November 23, 2009 fluid looks good so i guess its the belt. easy job? Quote Share this post Link to post Share on other sites
krnau 0 Posted November 24, 2009 I don't know, I have never done it myself. but I have seen it being done and does not look too difficult, but I can't really tell you how to do it, sorry :( Quote Share this post Link to post Share on other sites
