robtalbott
horrific squealing and loss of power steering
about a week ago the power steering (i assume) started squealing a bit on full lock (similar sound to a fan belt on its way out). this has now degraded rapidly to the point which it squeals whenever you try and steer either direction at very low speeds or standstill, and the steering goes VERY heavy and jerky.
this happen to anyone else? diagnosis/easy to fix?
also, would you continue to drive the car in this condition (is it likely to cause more damage)?
check your powersteering level and condition of oil, check belt condition and adjustment, :)
same as check the fluid sounds like you may have a leak
it happened twice to me
the 1st: broken PAS pipe, leak, no fluid
the 2nd: PAS belt not in tension.
good luck
I don't know, I have never done it myself. but I have seen it being done and does not look too difficult, but I can't really tell you how to do it, sorry :(
