Critical_Mass 10 Posted November 29, 2009 Hi all, need some help QUICK! I need to know which colour wire on the lambda goes to which wire on the ECU loom? Lambda i have a black and a grey, on the ECU side i have a yellow and a white. Which coloured wire goes to which? Thanks in advance! Gaz Quote Share this post Link to post Share on other sites
volksworld13 0 Posted November 29, 2009 ok are you on about the connector below the master cylinder, where the o2 sensor wiring is usually black.grey.or white. and on the loom side there is diffrent colours? are you talking about that connector? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 29, 2009 Yes thats the one. Does Grey (lambda) connect to the yellow (ecu)? Quote Share this post Link to post Share on other sites
volksworld13 0 Posted November 29, 2009 will just go check! Quote Share this post Link to post Share on other sites
volksworld13 0 Posted November 29, 2009 yes you are correct yellow to grey! alex Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 29, 2009 Ok, just connected it up and vagcom'd it and no fault :D Cheers for the fast response Alex... VERY much appreciated! :salute: Gaz Quote Share this post Link to post Share on other sites
