GREENY 0 Posted December 8, 2009 Hi please help if any1 can ..... ive just fitted new handles to both doors and are workin fine, started car up and it ran for bout 20 seconds the dies on me. Now if i turn the key all the ignition comes on and you can hear the fuel pump priming itself then turn and nothinks there ... :( wont even turn over! feel like dousin it in petrol and puttin a match to it!!!!!!! 1 thing after another. :censored: Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 8, 2009 Vr6, 16v, g60?? Sounds like fuse or relay related to me Quote Share this post Link to post Share on other sites
Slimg60 0 Posted December 8, 2009 When you try to crank push the key in quite hard, sounds like it might be a dodgy ignition connection. Failing that, take off the lower steering coloum cowling and give the plug on the ignition barrel a push when you try to start. Quote Share this post Link to post Share on other sites
GREENY 0 Posted December 9, 2009 Sorted !! :clap: cheers! Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 9, 2009 Waht was it?? Quote Share this post Link to post Share on other sites
GREENY 0 Posted December 9, 2009 I checked all fuses by talin them out and then puttin them back in , tried it and it fired up so must of been loose fuse or sumat... Thanks for ur help jon . cheers. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 9, 2009 No worries fella the good think about this forum theres always an answer to your problem Quote Share this post Link to post Share on other sites
