mimjed
need some help with the g please
finshed putting it back together today after a long fall out and started fine after a little cough revs shot straight round to 3500rpm. i killed it straight away - had a look at throttle cable, vacuum pipes etc all seemed to be fine.
started again fine revs stayed around 1200rpm but then creeped up to 1750rpm - when warm idles at 1500 rpm
anything blindingly obvious ive missed? i was thinking ecu vacuum pipe could have a kink in it, but too dark to see properly.
any help or suggestions please.
inlet/outlet manifold, exhaust. throttle body. fuel lines. all vacuum pipes. boost pipes. rocker cover and so on
hopefully it will be something dead simple. sadly doesnt normally work like that.
