culshaw
Rear pads replacement
Hi guys
I'm attempting to fit my rear pads tonight do they just sit in the carriers and you attach the caliper (is there no connection keeping the pads connected to the piston etc??)
much help appreciated
cheers
Ian
Thanks i've done the winding bit already thanks to davidworts guide!
Facing another problem here, this is probly real daft but! how do i fit goodridge hoses correctly if i fit the line to hose it goes fine but then when i try to fit it to the caliper the olive doesnt spin so twists the cable, is it a caliper off job and rotate the caliper to get it on??
depends what fitting is on the hose.
but if caliper off does the trick, why the hell not
err, not entirely sure where you mean.
i only used the copper washers on a banjo connection.
dont think they required on female swivel joints.
depends what you have and where you mean?
rear calipers bog standard corrado ones standard lines, goodridge hose female from the line to male at the caliper, im assumin i put the washer at the female end next to banjo?
go with them against the caliper so the hose clamps up on them. not convinced they are neede but wont do any harm to have them on
hi supercharged
there was no play in the hose or the union nut, see pic so it's a little twisted, whats the best way to fix it up?
so to make it a bit clearer the nut on the end of the brake line doesn't move (is that normal?), the female of the hose doesn't move nor does the male on the caliper end.
Yeah that does look a bit twisted - not ideal...
Yes the hose connectors are fixed so you tighten to the caliper first then run the free end to the hard line and tighten the union nut up to the connector on the hose.
