simonsxi
G11 to G12 antifreeze change
yes, as far as im aware there was issues previously but these were rectified with g12+ which is now just standard g12
The latest revision is G12++
I'd use the swap as a reason to flush the system completely.
Might be a good time to do the mk4 Golf header tank swap as its only £20ish to buy the parts needed from the stealers. Very easy to see your pink coolant levels once done :camp: . There's a guide on how to do it here in the engine bay section.
Where in south devon are ya? Good to see more local Corrados :wave:
just up the road in newton abbot :)
Cool, I'll keep an eye open to spot you. I hardly drive mine so could be hard to spot me.
Best of luck with doing the coolant.
A black VR = mmmm!
