culshaw 1 Posted December 27, 2009 I've start making the changes to my setup today before play got rained off but i'm having a problem with some elements of the setup, i've got the carrier, caliper and disc and pads on but theres no play in the setup at all. I've wound the caliper piston as far back as it will go; see pics they will explain it better. Discs are EBC standard 280mm calipers are off a 95 vr6, carriers came from same car. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 27, 2009 the problem probbaly is the pads,that set up is the G60,discs are G60 but are the calipers are VR6 ? im sure the offset of the G60 to VR6 discs are different,but unsure...you said would them in? fronts dont wind in but just push in,can you turn the brakes at all? Also note that the EBC pads have a thick "break in" layer and a good run up the road could sort out this problem.. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 27, 2009 Hmmm - no this should be ok... G60 and VR6 calipers / carriers are identical.... the pads you bought are the MK3 ones with a wear indicator but should be 19.6mm same as the Corrado ones. You could either sand the pads slightly or fit the 16v ons which are 3mm thinner each side in terms of material. Quote Share this post Link to post Share on other sites
corradog60stage4 0 Posted December 27, 2009 just remove the pads and use a belt sander to remove 1-2mm off each pad and you should be fine. Quote Share this post Link to post Share on other sites
culshaw 1 Posted December 27, 2009 thanks guys, i sanded the insides of the caliper down a bit getting some rust and high temp paint i put on out the way but will sand them down a bit. i've got pads with wear indicators, is it possible to get the wear indicator connector cable from a US spec corrado or a golf with this feature? would be a nice thing to have i think Ian Quote Share this post Link to post Share on other sites
