4eyes2wheels 0 Posted December 27, 2009 (edited) Not much else to say really, very standard, pretty clean. 73k miles, no rust, alarm / immobiliser, ok CD player, Aero wipers, Speedlines . . . . Edited March 16, 2013 by 4eyes2wheels Quote Share this post Link to post Share on other sites
VR6 0 Posted December 28, 2009 Looks good - nothing wrong at all with standard! Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted April 26, 2010 New wheels, Lupo GTI Wipers and colour matched grille - Oh no I've succumbed the pressure! Quote Share this post Link to post Share on other sites
vornwend 0 Posted April 26, 2010 Looks very smart - you're not finishing here tho are ya :wink: No pressure! Not entirely sure about the colour coded grill but I can't talk as I have 3 different grills :cuckoo: Quote Share this post Link to post Share on other sites
coullstar 0 Posted April 26, 2010 Wheels do look good on these but you do realise they are the wrong sized tyres on them? Quote Share this post Link to post Share on other sites
OSV 0 Posted April 26, 2010 Looks a nice car, but preferred it stock (with a drop) Quote Share this post Link to post Share on other sites
robrado974 1 Posted April 26, 2010 looking good mate looks in nice condition n how many miles!! must run as sweeeet as :) Quote Share this post Link to post Share on other sites
logix42p 0 Posted April 26, 2010 thats really nice fair play Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted April 26, 2010 Not entirely sure about the colour coded grill Haven't made my mind up yet so I'll hang on to the standard one for a while. Wheels do look good on these but you do realise they are the wrong sized tyres on them? They do take up more of the wheel arch than I was expecting, the ride is certainly higher over the traffic calming measures. I also note that the speedo indicates a lower speed that the sat nav by a couple of miles per hour at higher speeds. What size should be on them? They are Pirelli P6000 205/55 R16 . . . looking good mate looks in nice condition n how many miles!! must run as sweeeet as :) 73500 miles now, running well now the rubbish leads and failed camshaft sensor were replaced at DG on Friday. BUT gear box bearing making nasty noises in first. Looks a nice car, but preferred it stock (with a drop) Was expecting the suspension to be knackered and give me the justification to replace it but it seems in very good nick for the year. I'm told the later VRs run higher giving that 4x4 look. That's it for cosmetic changes - gearbox, chains and clutch next plus various bushes, joints and top mounts. Damn, there's no hope for me now! Quote Share this post Link to post Share on other sites
OSV 0 Posted April 26, 2010 15s run 205/50 so on a 16 i'd expect 205/45 or lower still, speedo will be out Stock Tire - 205/50R15 >Search Tires Tire 1 - 205/55R16 >Search Tires Tire 2 - 205/45R16 >Search Tires Section Width: 8.07 in 205 mm Section Width: 8.07 in 205 mm Section Width: 8.07 in 205 mm Rim Diameter: 15 in 381 mm Rim Diameter: 16 in 406.4 mm Rim Diameter: 16 in 406.4 mm Rim Width Range: 5.5 - 7.5 in Rim Width Range: 5.5 - 7.5 in Rim Width Range: 6.5 - 7.5 in Overall Diameter: 23.07 in 585.97 mm Overall Diameter: 24.87 in 631.69 mm Overall Diameter: 23.26 in 590.80 mm Sidewall Height: 4.03 in 102.36 mm Sidewall Height: 4.43 in 112.52 mm Sidewall Height: 3.63 in 92.202 mm Radius: 11.53 in 292.86 mm Radius: 12.43 in 315.72 mm Radius: 11.63 in 295.40 mm Circumference: 72.47 in 1840.7 mm Circumference: 78.13 in 1984.5 mm Circumference: 73.07 in 1855.9 mm Revs per Mile: 901.6 Revs per Mile: 836.3 Revs per Mile: 894.2 Actual Speed: 60 mph 100 km/h Speedometer1: 55.6 mph 92.7 km/h Speedometer1: 59.5 mph 99.1 km/h Speedometer Difference: - Speedometer Difference: 7.808% too slow Speedometer Difference: 0.827% too slow Diameter Difference: - Diameter Difference: 7.24% Diameter Difference: 0.82 Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted April 26, 2010 Soooooo, the tyres are OK for the wheels they are on BUT result in a higher rolling radius than intend for the Corrado. If the only consequences are the speedo misread and a slightly higher ride I can live with that. Quote Share this post Link to post Share on other sites
coullstar 0 Posted April 26, 2010 Yep 205/45/16's. Those are standard size for a Mk4 you have on. Here what it should look like. Quote Share this post Link to post Share on other sites
OSV 0 Posted April 26, 2010 8% out speedo will be out as will performance, should change tyres or stick with Speedlines, mofifications should ideally suit a car and offer improvements not compromised performance Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted April 26, 2010 Hmmm - thanks for the input chaps. Don't really want to change the tyres on the 16s as I'll end up with some P6000s to sell to the Golf community and end up losing more cash and the Speedlines will lose me cash too . . . . grrrrrr damn my impulsive ill informed automotive purchases!! Perhaps the speedlines need to go back on and move the 16s on again . . . . Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted May 28, 2010 The month of May saw some open wallet surgery - basically In the 8 months of VR6 ownership I have effectively bought the car again :shock: but that's the joy of Corrado ownership. The make over was performed by the splendid chaps at DG Autotech and comprised Replacement of all the plastic water housings and transfer pipes, flywheel, timing chains and guides, all the chains tensioners, rocker cover gasket, inlet manifold gaskets etc etc and while we're in there we might as well change the clutch.stromlaufplan_gamma4.pdfDSC04067.jpg[/attachment:21wswve8]ETKA Corrado.pdfDSC04069.jpg[/attachment:21wswve8]stromlaufplan_gamma4.pdfDSC04072.jpg[/attachment:21wswve8]Corrado92.pdfDSC04074.jpg[/attachment:21wswve8] The main reason for doing all this work was the fact that the gear box was making a nasty noise when in first gear so the box was removed and stripped and this was found to be the culpritpassat climatronic wiring diags.pdfDSC04096.jpg[/attachment:21wswve8] Reverse idler gear selector spring was broken and allowing the gear to 'rattle' against the main shaft gear. Heaven only knows what damage was being done but the guys next door to DG are gearbox gurus and were able to sort it by replacing the gearset and bearings - effectively a rebuilt gearbox then.climatronic wiring-Golf from May 01.pdfDSC04097.jpg[/attachment:21wswve8]2.8l 24v Climatronic system.pdfDSC04098.jpg[/attachment:21wswve8] Then there was a brake upgrade. Got some Mk3 Golf brake calipers from eBaycalipers.jpg[/attachment:21wswve8] which scrubbed up well and were matched up with EBC pads, VW OE 288 discs, DG 288 stainless steel brake conversion lines. These have improved the braking no end and just squeeze under the 15 inch Speedlines. Some top mounts and bearings and rear axle bushes, re-sealing some areas underneath and an engine flush and top end treatment . . . . . . Looks almost identical from the outside (apart from the bigger brakes) but the driving experience is much, much better. Thanks to Dave and Graham. Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted May 28, 2010 Meant to only change the title not repeat the previous post - D'oh! Quote Share this post Link to post Share on other sites
vornwend 0 Posted May 28, 2010 Some major pain there but you can't put a price on peace of mind. Were the chain guides very worn? Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted May 28, 2010 Guides were not too bad, striations (a word from my O-Level Geography days!) were clearly visible. Dave said "various cracks in top tensioner and guide but pad not too worn" it was one of those cases where once the gearbox came out I had invested over £200 in labour to that point so "might as well" get everything else sorted while we are there. Intention is to keep the car for a few years so for peace of mind and reliability sake it was worth it (I keep telling myself that!). Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted June 20, 2010 Started early. Good wash and towel dry. Clay bar the roof and the bonnet. Meguiars 3 Step system Paint cleaner Polish Wax Took a long time but it's nice and shiny now. Time for roast dinner, beer and Brazil v Cote D'Ivoire. Quote Share this post Link to post Share on other sites
DIGGER B 0 Posted June 20, 2010 Looking good there jon, all you need is a set of minty mint speedlines to go !! 8) Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted June 20, 2010 Looking good there jon, all you need is a set of minty mint speedlines to go !! 8) Let me know when you want to drop them off Stu - really keen to get them on! Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted July 25, 2010 Weekend of making things shiny. Newly refurbed Speedlines and new Toyos New rear VW and VR6 badges All red rears (All above from Digger B who also insisted on fitting everything - top bloke. If ever he sells his Black VR6 I'll be first in the queue and selling a kidney) Replaced bulbs for left side reversing and fog lights. Replaced clutch and brake pedal rubbers. Washed it Dried it Attacked it with 3M Finesse It (thanks for introducing me to this Digger) Meguiars Polish Meguiars Wax Auto Glym Glass Cleaner inside and out Had a go at the exhaust pipe with Autosol Brimmed it with £65 worth of Tesco Momentum 99 Looks much better than it did yesterday morning. Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted July 25, 2010 Better rear endquarter.jpg[/attachment:15wzvjpv] Quote Share this post Link to post Share on other sites
Jim 2 Posted July 25, 2010 I heartily recommend Autoglym product for Flash Red paint. Super resin polish, followed by Extra Gloss Protection and then a coat of their HD Wax does a cracking job, takes any oxidisation out of the paint and keeps it glossy for weeks and weeks :) Doesn't look too bad in the pics though I must say :) Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted July 25, 2010 Cheers Jim, the Megs stuff is OK but when it's gone I'll be looking at Auto Glym or maybe Dodo Juice Orange Crush . . .front view.jpg[/attachment:uw4hctu6] Quote Share this post Link to post Share on other sites
