culshaw
brake fluid reservoir hose to master cylinder hose fitting..
I'm having massive issues trying to get this hose back in after i got it out yesterday, can anyone give me the way they did it (if they had to replace it) or any possible solution please!!!!
thanks!!!!!!!!
2.0 16v
Did you pull the plastic bit out?
If so good luck! :)
No you should be ok - you will need to use a flatblade screwdriver and (carefully!) apply pressure to get it back in.
(Been there, done that!)
ok i tried to get it back in but it seems it will only go halfway back in (i've put the short end into the hole, applied more pressure than i would have thought it should do too... any ideas please?
