rob1234
G60 rev-limit / tacho redline
Just been watching the old Top Gear Corrado review (
At about 1.55, he says the limiter cuts in harshly at 6200rpm - but his tacho redline starts at 7k. Is this usual?!
PS I have a VR6 - is there any gain to having a higher rev-limit?
You can modify the map to increase the cut off, but not the best idea unless the engine is heavily modified, and requires it.
Well spotted - must have only had 16V clocks available - bl00dy Karmann!
You don't really ever want to rev a G60 past 6k anyhow, no need on an 8v
Also spot that the bonnet looks slightly open on some corners and the rear lights don't line up - shoddy for a press car!
Good overall review though
