mort1414 0 Posted January 10, 2010 started about a week ago gets worse with more speed and gets better as the car warms up video at slow speed Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 10, 2010 check your tyres,looks like you have a "Bleb" on one of the fronts Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted January 10, 2010 is it not an abs judder with you abs light being on and all that?? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 10, 2010 when the abs lights is illuminated the ABS is non fuctional. that would not cause that sort of fault. Quote Share this post Link to post Share on other sites
mort1414 0 Posted January 10, 2010 the abs light is on because the front left cable needs replacing just dont really want to do it in this weather and my coolant lite is flashing because i just fitted a mk4 expansion tank but need to wire it up. could it still be the abs affecting something like? Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted January 10, 2010 when the abs lights is illuminated the ABS is non fuctional. that would not cause that sort of fault. very true ignore my comment Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 10, 2010 the abs light is on because the front left cable needs replacing just dont really want to do it in this weather and my coolant lite is flashing because i just fitted a mk4 expansion tank but need to wire it up. could it still be the abs affecting something like? go outside,jack up one front side at a time and look at the tread while rotating the wheel,you will find the trye deformed,or has a distinctive high spot. Quote Share this post Link to post Share on other sites
mort1414 0 Posted January 10, 2010 just had a quick look and found a 'bleb' on the inside of tyre on the wall so cheers CorradoVR6-Turbo new tyres will be ordered shortly any idea wat cause these there 35 profile so hope the alloy is ok mort Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 10, 2010 low profiles are much more susceptible to curb damage or just poor tyres,just one of those things.. :( Quote Share this post Link to post Share on other sites
