mk4po-low
Relay 30
Right, funny story did an emergency brake today, felt somthing fly around in the footwell, had a root around and four the number 30 relay! can someone tell me where it goes please!?!?!
Does your engine still run?
According to the electric string manual the only relay coded with '30' is for the ECU on a 2.0l 8v car or a G60(which I am going to guess you have) if so it goes into position 3 on the relay board (top row 3rd from the left).
If there is one already in there then it must be a spare as number 30 is not showing up for anything else.
This fella bought the 8v with running problems that was for sale recently, the seller said they'd tried the ECU so they probably also tried the relay too :)
