gtg40 0 Posted January 21, 2010 Hello Please could anyone help me with ths problem. My ABS is playing up and wouldn't pass the MOT because the abs light stays on. i've got this fault code: 00257 - ABS Inlet Valve-Left Front (N101) Any ideas what this could and how i could fix it? thanks ste Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted January 21, 2010 00257 1112 Left Front ABS Inlet Valve -N101 Faulty wiring, wiring connection or valve coil. Possibe cause Malfunction at contact 3 of ABS Control Module (J104). Corrective step Test wiring, wiring connections and valve coil: Quote Share this post Link to post Share on other sites
gtg40 0 Posted January 23, 2010 00257 1112 Left Front ABS Inlet Valve -N101 Faulty wiring, wiring connection or valve coil. Possibe cause Malfunction at contact 3 of ABS Control Module (J104). Corrective step Test wiring, wiring connections and valve coil: Sorry i've not had the corrado long. where would the ABS control module be? thanks Quote Share this post Link to post Share on other sites
pete_griff 0 Posted January 23, 2010 there's a bit of "kick" trim under the shelf in the passenger footwell. it's on the side of the car, just in front of the door-gap. water can get in there if you have a dodgy scuttle seal etc (mine was badly corroded the first time i had it apart). worth checking there as a starting point as it's only two screws to take the panel off iirc. (you'll have to take the plug off the module to see it obviously and then it should be obvious if water/corrosion has in-set) Quote Share this post Link to post Share on other sites
