culshaw
Nearside ball joint 'loose'
Hi, a while back i got a strict list of what was wrong with the car and it mentioned a loose n/s/f ball joint, would this be a case of being replaced or getting tightened/pressed? If its the former has anyone got a part number handy to get a price? Even if you can get one from ECP or GSF wuld be handy if needs be to chuck it through the MOT before i start the meaty work :D
Thanks
Ian
Replace - get it from VW only - they are around £20 including the 2 bolts and the pinch bolt and nut you need.
Pattern ones don't last at all - been there, done that!
thanks mate, was expecting vw to be about 40 quid but when i rang up this mornin i was considering getting two!
